PEAP-MSCHAPv2 & MAC-AUTH with WEP on same AP
Jul 12th, 2007
is it possible to have PEAP-MSCHAPv2 authentication and MAC Authentication against Central Cisco ACS, on the same Access Point on different SSID's without conflicting with each other?
Jorge
rnigam Sat, 07/14/2007 - 03:36
The answer would depend upon the configuration done on the AP..
a) if you have configured vlans on your AP then you can set SSID , map it to each vlan and accordingly configure encryption to each vlan
b) if there are no vlan then too the two ssid would work but you then you have to have the same encryption on both the ssid.
Trending Topics - Security & Network
