Newbie routing question on 1841
Jul 12th, 2007
Hi all,
I believe I am having a routing issue on a 1841 router.
The connection is like this (IPs changed):
ISP router (10.87.94.77/30)
1841 Serial (10.87.94.78/30)
1841 FE0/0 (192.168.100.1)
I can ping and trace to the internet from the serial interface but not the FE0/0 interface (or the FE0/1 which was setup just to see if there was an issue with the other interface).
I am using a static route:
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
It just isn't working.
Any ideas on what I am missing? I expect it is something basic, but I am not sure what.
Another thing is that when doing a show ip route, I get:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
Any help would be greatly appreciated.
Matt
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 07/12/2007 - 02:24
you are missing NAT.
I suggest you quit with the SDM now and do manual configuration that will permit you to learn how things work:
interface serial
ip nat outside
interface ethernet
ip nat inside
ip nat inside source list 101 interface serial overload
access-list 101 permit ip 192.168.x.0 0.0.0.255
replace x with whatever network you will be using.
hope this helps, please rate post if it does!
