Vpn client output
mheusing Thu, 07/12/2007 - 07:29
  • Cisco Employee,
Make sure the Cisco VPN service is started. You can check this from the "Services" control panel or more simple with the task manager, where you should see a process called "cvpnd.exe".
If this service is not started it will create the message you experienced.
Hope this helps! Please rate all posts.
Regards, Martin
