Access Citrix-Terminalservices via WebVPN and Java-Client
Jul 12th, 2007
we set up a WebVPN on a CISCO 1812 router (IOS-Version 14.4(9)T) and want to access our Citrix PS 4.0 webfrontend to run a published application with the citrix-java-client.
Accessing the webfrontend, running the application with the activex-citrix-client functions properly, but trying to start the published application with the java-client results in an error message, that the presentation-server can't be found. Sometimes the JRE shows it's coffeecup, but after a few minutes there is only an empty window with a red cross.
I read that it's important that the CN-entry of the certificate represents the fqdn of the VPN-Gateway. But that's guaranteed.
Further I imported the certificate to the "trusted rootcertificate memory" of the internet explorer and imported it with the "keytool.exe" to the certificate memory of the JRE.
The option "SSL/TLS" at the the citrix client-allocation is activted too.
The newest version of the JRE is installed.
Does anybody have this constellation running in a productive environment?
Output of sh run:
crypto pki trustpoint test-trust
enrollment selfsigned
serial-number none
fqdn my-fqdn
ip-address none
subject-name CN=my-fqdn
revocation-check crl
rsakeypair test-trust
webvpn gateway webvpn
hostname test-citrixfarm
ip address XXXXXXXXX port 443
http-redirect port 80
ssl encryption 3des-sha1
ssl trustpoint test-trust
webvpn context webvpn
title "Our-WebVPN"
ssl authenticate verify all
url-list "Our-Websites"
heading "Testservers Testlab"
url-text "Test-Citrixfarm" url-value "http://ip-adresse-internal-LAN"
policy group pol1
nbns-list "NBNSServers"
functions file-access
functions file-browse
functions file-entry
citrix enabled
default-group-policy pol1
gateway webvpn
max-users 2
Thanx for your help.
didyap Wed, 07/18/2007 - 12:23
In the C:\inetpub\wwwroot\citrix\metaframe\conf directory, edit the default.ica file and add the line [SSLEnable=On]
in the Application Section - right above the line that says [EncRC5-0]:
niedax_edv Wed, 07/18/2007 - 23:43
Thanks for your answer, but I get the same result: Only the red-cross.
