Nat issues.
Answered Question
Jul 12th, 2007
Hello. I have a cisco 2811 router with an adsl connection.In the local LAN there is a Linksys load balancer which connects the local lan with the router.However there is a server which connects directly to the router and i want to be able to forward some ports to this server.The router ip is 192.168.10.1 the linksys ip is 192.168.10.2 and the server ip is 192.168.10.213.I want to forward port 2000 and 85 to be sent to the server and not to the Linksys (local LAN).There is already a NAT translation for internet access.Any ideas how can i do that???Any help will be welcome.Thanks in advance.
Correct Answer by Edison Ortiz about 10 years 1 week ago
Can you post your current template so I can work from that ?
Basically, you need to create an ACL and then a nat source list.
access-list 100 permit tcp 192.168.10.213 eq 2000 any
access-list 100 permit udp 192.168.10.213 eq 2000 any
access-list 100 permit tcp 192.168.10.213 eq 85 any
access-list 100 permit udp 192.168.10.213 eq 85 any
ip nat inside source list 100 interface [external interface] overload
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 07/12/2007 - 09:30
  • Hall of Fame,
    Founding Member
bjornarsb Sat, 07/14/2007 - 04:01
  • Bronze, 100 points or more
Or like this:
ip nat inside source static 192.168.10.213 172.16.10.X
or
this
ip nat inside source static tcp 192.168.10.213 2000 172.16.10.8 2000
BR,
Bjornarsb
