3745 and HWIC ADSL
Answered Question
Jul 12th, 2007
I was just wondering if the 3745 will support HWIC's in particular the HWIC-1ADSL for ADSL2 or 2+, or does it just support the WIC-1ADSL?
Cheers,
Brett
Correct Answer by Martin Parry about 9 years 10 months ago
The 3745 does not have any HWIC slots, so unfortunately the HWIC-1ADSL is not supported. You will need an ISR to accomodate these modules
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd80394b7e.html
MP
Overall Rating: 5 (1 ratings)
brett@hardcore-... Thu, 07/12/2007 - 04:41
OK no problems, just thought it might be compatible. Now I know which WIC I can buy for it.
Cheers for the quick reply.
