Possible To Only Have To Enter Password 1 time?
Jul 12th, 2007
I have configured some of our network devices to authenticate to our TACACS server. Some of the network engineers have asked me to see if I can come up with a way that they don't have to type in their password twice on the network devices. I saw a different thread,
and I followed what was stated in their, however I still have to type in my password twice. I have made sure that they shell privilege level is set for 15. Anyone have any ideas?
Attached is the related router config.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
tacacs-server host
tacacs-server host
tacacs-server key 7 <omitted>
Thanks for the help.
somishra Thu, 07/12/2007 - 05:59
Remove the command -
Hope this helps,
pugs17211721 Thu, 07/12/2007 - 06:45
If I do a
no aaa authentication enable default group tacacs+ enable
then when I try to sign in, I get NBOH-2940-001-IS>en
% Access denied
I have attached a screenshot of the ACS server.
parmsing Thu, 07/12/2007 - 06:50
First of all, if you have exec command and shell priv option checked you should be in # prompt, you should not be following in user> mode. Please send the following debugs when trying authentication.
-debug aaa authentication
-debug aaa authorization
-debug tacacs
Jagdeep Gambhir Thu, 07/12/2007 - 06:51
Hi ,
What is the IOS ver you have on the box. Please make sure that the attachment is from tacacs and not the other one.
Make sure that you are a part of that group on which changes has been made. Also check if you have anything set at user level ?
parmsing Thu, 07/12/2007 - 06:03
As you already have aaa authorization exec command in place, You only have to enable the privilev level field under Tacacs+ settings on group and mention 15 as privilege there and that should do it.
I have attached screen shoot for your reference.
Jagdeep Gambhir Thu, 07/12/2007 - 06:04
No need to do enable authentication.
Please take that out and it will work fine.
