How to verify allocated directory numbers?
Answered Question
Jul 12th, 2007
for a given location (same prefix in dial plan), the dn's are allocated to devices, cti's, and device profiles. a device search will not include the device profile numbers. Any suggestions on how to search to find all the allocated dn's for a given prefix? Thanks.
Correct Answer by Rob Huffman about 9 years 10 months ago
Hi Darrell,
Have you tried using this report;
Route Plan Report
The route plan report lists all assigned and unassigned directory numbers (DN), call park numbers, call pickup numbers, conference numbers, route patterns, translation patterns, message-waiting indicators, voice mail ports, and Cisco CallManager Attendant Console pilot numbers in the system. The route plan report allows you to view either a partial or full list and to go directly to the associated configuration windows by clicking the Pattern/Directory Number, Partition, or Route Detail fields.
In addition, the route plan report allows you to save report data into a .csv file that you can import into other applications. The .csv file contains more detailed information than the web pages, including directory numbers for phones, route patterns, pattern usage, device name, and device description.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed686.html#wp1024696
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 07/12/2007 - 07:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Darrell,
Route Plan Report
From this good doc;
Hope this helps!
Rob
