Calling Line Restricted Problem
Jul 12th, 2007
Hi to all,
in the following scenario ccme interconnected to Panasonic KX-TD-816-232 PBX through ISDN BRI, can't see calling line ID on incoming(for ccme) calls.
In voip ccapi debug i see Presentation=Restricted on the incoming dial-peer 10. Tried to override this field with no success. Please help with this. Will atach debug and running config.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Thu, 07/12/2007 - 12:36
Indeed the PBX is placing the call with presentation restricted:
Calling Party Number i = 0x01A1, '114' <-- BIT 5 is set !
Hence IOS is dutifully restricting CLID.
Please check PBX configuration to allow CLID presentation.
