MGCP Gateway Registration Failure with CCM 5.1
Jul 12th, 2007
Hi all,
I summarize you my problem;
When you use an MGCP gateway in Cisco CallManager 5.1, the gateway shows as registered in show ccm−manager command output, but gateway shows as unregistered in the Cisco CallManager Administration page.
This issue is emerged after one day (or more) that the registration has been done.
thanks
best regards
Michele
Chris Deren Thu, 07/12/2007 - 13:25
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What version of IOS are you using? can you post your confi?
Chris
