07-12-2007 07:27 AM - edited 03-05-2019 05:15 PM
I installed a new VWIC2-1MFT-T1/E1 card in my cisco 3825 router, and the router does see it, but I am unable to configure the "controller T1".
2 Gigabit Ethernet interfaces
60 Serial interfaces
8 Channelized T1/PRI ports
1 Channelized (E1 or T1)/PRI port
The new card is in slot 0/3, but I keep getting the error below:
RS_3825(config)#controller t1 0/3/0
% Invalid input detected at '^' marker.
Please help.
Thanks.
hieu
Solved! Go to Solution.
07-12-2007 07:55 AM
Try the global command:
card type t1 0 3
You need to identify to the router if your using it as a T1 or E1
07-12-2007 07:55 AM
card type t1 0 3
07-13-2007 08:25 AM
Hello Chris,
Thank you for your help. I did just that and it worked great.
hieu
07-13-2007 03:42 AM
plz paste the show diag output..
cheers :)
satish
