Rob Huffman Thu, 07/12/2007 - 09:19
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sudheer,
Support for IP Communicator was added in CME 4.0 Have a look at the steps below;
SCCP: Configuring Cisco IP Communicator Support
To enable support for Cisco IP Communicator, perform the following steps.
Prerequisites
Cisco Unified CME 4.0 or a later version
Cisco IP Communicator 2.0 or a later version
IP address of the Cisco Unified CME TFTP server
(Optional) Headsets with microphones for users
DETAILED STEPS
Step 1 Download the latest version of the Cisco IP Communicator software and install it on your PC.
The download website is at http://www.cisco.com/pcgi-bin/tablebuild.pl/ip-iostsp.
Step 2 (Optional) Attach a headset with microphone to your PC.
Step 3 Start the Cisco IP Communicator application.
Step 4 Define the IP address of the Cisco Unified CME TFTP server.
a. Open the Network > User Preferences window.
b. Enter the IP address of the Cisco Unified CME TFTP server.
Step 5 Wait for the Cisco IP Communicator application to connect to Cisco Unified CME and register.
Step 6 Configure the extension numbers and line buttons for the Cisco IP Communicator.
Use the normal phone provisioning commands described in the "SCCP: Creating Directory Numbers" section. In the type command, use the CIPC keyword to identify this phone as a Cisco IP Communicator.
SCCP: Verifying Cisco IP Communicator Support
Step 1 Use the show running-config command to display ephone-dn and ephone information associated with this phone.
Step 2 After Cisco IP Communicator registers with Cisco Unified CME, it displays the phone extensions and soft keys in its configuration. Verify that these are correct.
Step 3 Make a local call from the phone and have someone call you. Verify that you have a two-way voice path.
SCCP: Troubleshooting Cisco IP Communicator Support
Step 1 Use the debug ephone detail command to diagnose problems with calls. For more information, see the Cisco Unified CME Command Reference.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807e13a7.html#wp1046762
Hope this helps!
Rob
ev1205 Fri, 01/23/2015 - 10:26
Rob THANKS AGAIN !!!
Enrique Villasana
sudheer.gundlapally Thu, 07/12/2007 - 13:46
Thanks Rob
I am able to configure the IP communicator and it is registering with CME. I have another question.. how can i configure IP communicator to use my desk phone number instead of giving a new number.
