port address translation using static route problem
Jul 12th, 2007
I am trying to translate two ports from outside to inside the port using static routes
static (inside,outside) tcp 111.222.333.444 65002 192.168.0.1 65002 netmask 255.255.255.255
Static (inside,outside) tcp 111.222.333.444 5060 192.168.0.1 65002
When I try to apply the second static statement I receive a duplicate entry error message.
Can anyone help with correctly setting up a PIX 515 to do the translation cos I am pulling my hair out, and I don't have much to lose.
Dave
acomiskey Thu, 07/12/2007 - 09:36
  • Green, 3000 points or more
It's not anything you're doing wrong, the pix simply will not let you do what you're trying to do.
