HSRP question
Hi,all
we have to routers configured for internet. they are oonfigured as HSRP.
on one of our monitoring tools. we can ping two real interfaces on the two router but not the virtual IP. it is on and off.
what might be the problem?
thanks,
Han,
on one of the routes, the configruation is:
interface GigabitEthernet0/3
description to abc FW Cluster
ip address A.B.C.3 255.255.255.0
ip access-group block_outgoing in
ip access-group Media_Public_out out
no ip redirects
ip route-cache same-interface
ip route-cache flow
duplex auto
speed auto
media-type rj45
no negotiation auto
standby 1 ip A.B.C.1
standby 1 priority 150
standby 1 preempt
standby 1 track Serial3/0
end
Overall Rating: 4 (3 ratings)
Edison Ortiz Thu, 07/12/2007 - 11:16
  • Hall of Fame,
    Founding Member
Do you have the same priority on both ?
Can you post the output from typing
show stand
from both routers ?
bjornarsb Fri, 07/13/2007 - 08:44
  • Bronze, 100 points or more
Do you have configured.
Stanby 1 mac ?
BR,
Bjornarsb
Amit Singh Fri, 07/13/2007 - 09:17
  • Cisco Employee,
Your interface description tells that the routers are connected to a FW cluster. We would like to check your over all network topology to check what could possible be the problem.
Whenever you enable HSRP on the physical interfaces the " IP redirects" gets disable. I have personnaly seen these kinds of problem in some of the networks. Try enable " standby redirects " under the interface config and see if that helps.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t3/dt_hsrpi.htm
HTH,Please rate if it does.
-amit singh
