l2l VPN with NAT on Router
mattiaseriksson Thu, 07/12/2007 - 14:05
Hi there, it looks ok except that you will most likely have a NAT problem.
You will probably end up NAT:ing all traffic, not only traffic to 10.10.0.0/16.
In order to NAT based on destination addresses you should use route maps like this. From the top of my head:
access-list 108 permit ip any 10.10.0.0 0.0.255.255
route-map NAT-DST permit 10
match ip address 108
ip nat inside source route-map NAT-DST pool NATPOOL overload
Something like that
mattiaseriksson Fri, 07/13/2007 - 02:02
@[email protected]:
Yes, the names are wrong, I forgot to mention that in my post.
What I tried to explain was that when you do destination-based NAT you should use route-maps, because it will always create an extended translation entry.
That will ensure that the packet will only get NAT'd if it matches the route-map statement, even if there is already a NAT entry for the same local IP address.
NAT with an extended ACL will work in most situations, but it could fail as it sometimes creates only a simple translation entry.
