Faxing/Dialup Modem on Aironet 1410 using IP trunking
Jul 12th, 2007
Need to know whether there is a limitation for faxing or dialing up a modem that is connected via VoIP Trunks when those trunks communicate on a Aironet 1410.. Good voice between the two, but can't access a modem that is connected to the remote end. Modem answers, just the two never quite get the handshaking done to negotiate a baud rate.
Any help would be greatly appreicated.
janf Fri, 07/13/2007 - 09:29
We had problems with faxing via VoIP using compression over the 1400 bridges. As a rule we no longer do any compression on fax lines through our VoIP network.
