07-12-2007 11:17 AM
What version is required to uses reverse SSH, I have 12.4 running, not able to find the commands, to enable reverse SSH.
07-17-2007 08:10 AM
Reverse SSH has been there since 12.2, but that version required the use rotary group configuation. With 12.3(11)T, there has been enhancements , making the configs simpler.
So in 12.4 :
Example:
line 1 3
no exec
login authentication default --
transport input ssh
The below url has some examples for reverse ssh.
07-17-2007 08:51 AM
Thanks for the information, i have a question the only command that I cannot uses is login authentication default, the version of code that I am running is c2800nm-advipservicesk9-mz.12.4-1b.
07-17-2007 09:00 AM
To have the login authentication default command,
use the below commands:
aaa new-model
aaa authent log default local
user
Then you can add the command
login authen def
under the line.
