NAT through VPN
Answered Question
Jul 12th, 2007
I am havening trouble with NAT over VPN. with the current configs below it will complete phase one of the tunnel then stop because the ip is not natted. if i put a permit any in the permit statement it will nat to the internet from the host but not over the vpn. if i put in a static nat statement it will nat and attempt to create a tunnel but i receive the error (incrementing error counter on sa, attempt 1 of 5: retransmit phase 1)
version 12.3
service password-encryption
hostname BatsVpnRouter
boot-start-marker
boot system flash c1700-k9o3sy7-mz.122-13.T.bin
boot-end-marker
no logging console
enable secret xxx
enable password xxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
no ip subnet-zero
ip cef
ip audit po max-events 100
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxx address 190.0.0.1
crypto ipsec transform-set BATS esp-3des esp-sha-hmac
crypto map bats_map 2 ipsec-isakmp
set peer 190.0.0.1
set transform-set BATS
--More-- match address BATSACL
interface Ethernet0
ip address 11.0.x.x.255.255.224
ip nat outside
full-duplex
crypto map bats_map
interface FastEthernet0
ip address 192.168.1.2 255.255.255.0
ip nat inside
speed 100
full-duplex
ip nat inside source list bats-nat interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 11.0.0.1
no ip http server
no ip http secure-server
ip access-list extended BATSACL
permit ip host 11.0.0.5 host 200.0.0.1
permit ip host 192.168.1.100 host 200.0.0.1
permit ip host 11.0.0.5 host 200.0.0.2
permit ip host 192.168.1.100 host 200.0.0.2
permit ip host 11.0.0.5 host 200.0.0.3
permit ip host 192.168.1.100 host 200.0.0.3
ip access-list extended bats-nat
permit ip host 192.168.1.100 host 200.0.0.1 log
snmp-server community public RO
snmp-server enable traps tty
alias exec clip clear ip rou *
alias exec crs copy run start
alias exec deb187 debug ip pack det 187
alias exec ospfnei sh ip ospf nei
alias exec ship sho ip route
alias exec shr sho run
alias exec siib show ip inter brief
alias exec sip sho ip pro
alias exec tr traceroute
alias exec ss sho sess
alias exec sl sho line
alias exec cl clear line
line con 0
line aux 0
line vty 0 4
password xxx
login
Correct Answer by mattiaseriksson about 9 years 8 months ago
Ok. You need to make sure that the ACl:s are identical (but mirrored) on both sides, which means you probably need to remove some lines on router 1. The ACL should look like this:
Then remove the 'log' keyword from this line:
Ok now you have cleaned up, try to bring up the tunnel again, try with both 200.0.0.1 and 200.0.0.2.
Then check the remote debug again.
Overall Rating: 5 (1 ratings)
mattiaseriksson Thu, 07/12/2007 - 14:43
  • Bronze, 100 points or more
Hi, the problem is that NAT with access-lists don't give you a detailed control over the translation entries.
with the route-map method you ensure that the decision of the address to translate to is done on a per flow basis rather than once.
route-map nat-me permit 10
match ip address bats-nat
ip nat inside source route-map nat-me interface Ethernet0 overload
jimwysocki Fri, 07/13/2007 - 08:35
I edited the configs as attached below. when i first did the statement it completed phase 1 but i could not transfer traffic through the tunnel. I saved the configs and restarted to get a debug of the action from the start. upon debugging after the restart no data was natted. i have attached my debug file, thank you
version 12.3
boot-start-marker
boot-end-marker
no logging console
enable secret xxx
enable password xxx
no mmi pvc
no aaa new-model
no ip subnet-zero
ip cef
encr 3des
group 2
set peer 190.0.0.1
interface Ethernet0
ip address 11.x.x.5 255.255.255.224
ip nat outside
full-duplex
crypto map bats_map
ip nat inside
speed 100
full-duplex
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password xxx
login
mattiaseriksson Fri, 07/13/2007 - 09:29
Ok, the debug is from the initiator side and does not really give you an explanation. Can you get the debug from the other side?
But first check your access-lists used in the crypto map on both sides, that is a common cause for this to happen!
Otherwise attach the debug from the other end of the tunnel.
jimwysocki Fri, 07/13/2007 - 11:11
Here is the debug info from the remote firewall
Jul 10 16:49:48 [IKEv1]: Group = 11.0.0.5, IP = 11.0.0.5, Static Crypto Map check, map = outside_map, seq = 50, ACL does not match proxy IDs src:192.168.1.100 dst:200.0.0.1
Correct Answer
mattiaseriksson Fri, 07/13/2007 - 11:38
