ACE and AAA (TACACS+)
Answered Question
Hi there,
i have configuerd my acs with an custom attribute : shell:Admin=Admin. AAA with the ACE works fine... But now i can't login into my switches :-( i got the massage authorization failed. Here is the aaa debug from the switch :
Jul 12 13:41:38.433 UTC: AAA: parse name=tty2 idb type=-1 tty=-1
Jul 12 13:41:38.441 UTC: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
Jul 12 13:41:38.441 UTC: AAA/MEMORY: create_user (0x16E1F28) user='NULL' ruser='NULL' ds0=0 port='tty2' rem_addr='*******' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Jul 12 13:41:44.590 UTC: tty2 AAA/AUTHOR/EXEC (945064986): Port='tty2' list='' service=EXEC
Jul 12 13:41:44.590 UTC: AAA/AUTHOR/EXEC: tty2 (945064986) user='*******'
Jul 12 13:41:44.590 UTC: tty2 AAA/AUTHOR/EXEC (945064986): send AV service=shell
Jul 12 13:41:44.590 UTC: tty2 AAA/AUTHOR/EXEC (945064986): send AV cmd*
Jul 12 13:41:44.590 UTC: tty2 AAA/AUTHOR/EXEC (945064986): found list "default"
Jul 12 13:41:44.590 UTC: tty2 AAA/AUTHOR/EXEC (945064986): Method=tacacs+ (tacacs+)
Jul 12 13:41:44.590 UTC: AAA/AUTHOR/TAC+: (945064986): user=*******
Jul 12 13:41:44.590 UTC: AAA/AUTHOR/TAC+: (945064986): send AV service=shell
Jul 12 13:41:44.590 UTC: AAA/AUTHOR/TAC+: (945064986): send AV cmd*
Jul 12 13:41:44.799 UTC: AAA/AUTHOR (945064986): Post authorization status = PASS_ADD
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: Processing AV service=shell
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: Processing AV cmd*
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: Processing AV priv-lvl=15
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: Processing AV shell:Admin=Admin
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: received unknown mandatory AV: shell:Admin=Admin
Jul 12 13:41:44.799 UTC: AAA/AUTHOR/EXEC: Authorization FAILED
Jul 12 13:41:46.804 UTC: AAA/MEMORY: free_user (0x16E1F28) user='*******' ruser='NULL' port='tty2' rem_addr='*******' authen_type=AS
Any idea what's wrong ??
Best regards Dirk
Correct Answer by Premdeep Banga about 10 years 1 week ago
Hi Dirk,
Any specific reason/requirement, that you have to configure attribute, shell:Admin=Admin ?
Apart from the device is rejecting it, as it is not able to understand it, and on top of that we have made it a mandatory attribute.
Try this,
shell:Admin*Admin
* -> Optional Attribute
Prem
Overall Rating: 5 (3 ratings)
Correct Answer
Premdeep Banga Thu, 07/12/2007 - 15:30
  • Gold, 750 points or more
Hi Dirk,
Try this,
shell:Admin*Admin
Prem
Premdeep Banga Thu, 07/12/2007 - 15:40
Nevermind....
Try, shell:Admin*Admin
Prem
