07-12-2007 01:51 PM - edited 03-11-2019 03:44 AM
The ASA we have is running Cisco Adaptive Security Appliance Software Version 7.0(6)
Device Manager Version 5.0(6)
Some docs I have seen say the WEBVPN is a trial but does not say anymore than that. Is it limited by functionality or the number of connections? The only docs I have found on configuring WebVPN via ASDM seems to relate to the later version and uploading the SSL client presumably this is only supported with the later version of software.
What will work with what we have as far as the WEBVPN is concerned. Are there any differences configuring via CLI for the diferent versions of S/w i.e can I use the same commands/features?
Compiled on Tue 22-Aug-06 13:22 by builders
System image file is "disk0:/asa706-k8.bin"
Config file at boot was "startup-config"
ShpasaOne up 52 days 14 hours
failover cluster up 52 days 3 hours
Hardware: ASA5520-K8, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0 : address is 001a.a22d.126e, irq 9
1: Ext: GigabitEthernet0/1 : address is 001a.a22d.126f, irq 9
2: Ext: GigabitEthernet0/2 : address is 001a.a22d.1270, irq 9
3: Ext: GigabitEthernet0/3 : address is 001a.a22d.1271, irq 9
4: Ext: Management0/0 : address is 001a.a22d.126d, irq 11
5: Int: Not licensed : irq 11
6: Int: Not licensed : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
This platform has an ASA 5520 VPN Plus license.
07-18-2007 01:34 PM
Clientless SSL VPN (WebVPN) allows for limited but valuable secure access to the corporate network from any location. Users can achieve secure browser-based access to corporate resources at anytime. This document provides a straightforward configuration for the Cisco Adaptive Security Appliance (ASA) 5500 series to allow Clientless SSL VPN access to internal network resources.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00806ea271.shtml
