ACE Probe
Syed Iftekhar Ahmed Fri, 07/13/2007 - 01:08
It the help function of the parser that is causing problem fro you.You can achieve your goal by entering a question mark through this combination :
followed by "?"
So you type Control-V and then (without a space) immediately after the question mark.
Syed Iftekhar Ahmed
