making a ip telephony network
Answered Question
Jul 12th, 2007
hi everybody i wanna help making my first voip telephony network i only want to make calls between phones in the network i dont wanna make calls to external phones only internal calls so i m using a cisco 2811 but i dont know if i need another hardware some card i dontknow to make my voip network i only wanna know the hardware needed i can take care of the configuration so please help me
Correct Answer by paolo bevilacqua about 9 years 11 months ago
Hello, as I was saying before, when there are no ANALOG phones or connections to the PSTN, The PVDM2 module is not needed.
As a recognition to those providing answers, please rate all useful posts using the scrollbox below!
Overall Rating: 3.7 (4 ratings)
paolo bevilacqua Fri, 07/13/2007 - 01:14
  • Hall of Fame,
    Founding Member
you just need the phones now and are ready to make calls, search CCO for "CME" and start reading the documentation, just the basic and few minuts it will be working.
Hope this helps, please rate post if it helps!
malamigo55 Fri, 07/13/2007 - 13:56
so you mean i only need the 2811 router (im working with this), a switch (can it be from another brand??) and a cisco IOS that supports voip and CME
im all rigth???
d.bigerstaff Fri, 07/13/2007 - 15:48
You only need:
Router running an IOS with CME. 2811 will run that IOS fine as I have a few of these in the office for this purpose.
Any Switch will be fine, but depending on switch features you might lose some IP Phone benefits.. such as power over ethernet.
And Cisco IP phones.
malamigo55 Fri, 07/13/2007 - 18:52
thanks you i wont be using a cisco switch i hope it will be fine, a simple switch no special feature, i think i will use a liksys or a d-link switch
so by the way i see that cisco offer a voice bundle with this switch it comes with more ram and flash and so it comes with some card named PVDM2
what is the purpose of that card and why do they include it in the voice bundle, the only card they include only ram flash and this card.
this is the final question and thanks everybody lets make well lets buy the things for make the voip
paolo bevilacqua Sat, 07/14/2007 - 01:17
  • Hall of Fame,
    Founding Member
The PVDM2 is a DSP card needed for interfacing analog phones, or lines to the PSTN.
So if you intention is not use only VoIP calls, and perhaps use an ITSP for circuits, you don't need it.
malamigo55 Sat, 07/14/2007 - 20:34
no really i will only connect cisco ip phones in my LAN only like five phones but all in my own LAN in same the router is.
thats my question do i need that card, i dont know i will be using only cisco ip phones the cisco 2811 router and a d-link switch to cennect the phones
Router ---- Switch ------ IP PHONES
computers and
servers
Correct Answer
paolo bevilacqua Sun, 07/15/2007 - 03:00
  • Hall of Fame,
    Founding Member
malamigo55 Sun, 07/15/2007 - 10:22
thanks very much but by the way i dont need a cisco switch to make the cisco ip phones got to work?? im correct because a cisco router and switch for this is too expensive
paolo bevilacqua Sun, 07/15/2007 - 16:56
  • Hall of Fame,
    Founding Member
No you don't need a cisco switch for the phones to work. However I suggest you use a switch with PoE because the phone's power supply is a nuisance. Linksys makes nice switches and they are cheap.
Thanks for the nice rating and good luck!
malamigo55 Sun, 07/15/2007 - 18:47
thats you helped me a lot with this, i didnt know how to begin with this no i think i will use a converter for the outlet to a PoE so i will use the something like a converter
paolo bevilacqua Sun, 07/15/2007 - 23:39
  • Hall of Fame,
    Founding Member
Watch out, PoE injectors are expensive, your best choice is a PoE switch.
Grad to know it helped, thanks for the nice rating and good luck!
