dgahm Thu, 07/12/2007 - 22:13
  • Blue, 1500 points or more
Request timeout simply means no response was received before the timeout period expired. Destination unreachable is an ICMP message generated by a router that was unable to forward the packet and sent to the source of the packet.
Please rate helpful posts.
Dave
guruprasadr Fri, 07/13/2007 - 04:34
  • Gold, 750 points or more
HI,
If a request times out, it means that your computer did not receive a response at all. It's the equivalent of calling someone and having the phone ring hundreds of times until you decide to give up.
The Destination Host Unreachable message means that a router sent you back an error and is equivalent to a busy signal.
PLS Rate if HELPS
Best Regards,
Guru Prasad R
