paolo bevilacqua Fri, 07/13/2007 - 01:28
  • Hall of Fame,
    Founding Member
No, it does not.You will need H323 on the GW for E1-R2.
mike.lo Fri, 07/13/2007 - 03:05
so, where can i get the configuration in h323 connection?
paolo bevilacqua Fri, 07/13/2007 - 03:08
  • Hall of Fame,
    Founding Member
config for E1 R2 is very peculiar to country and telco. Where are you located ? In the forum there are posts with examples for telmex and few others. For an introductory discussion, see:
http://cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800942f2.shtml
Advice: if you have _any_ chance to have the circuit provision as PRI instead, do that. E1 R2 is very challenging to configure and troubleshoot if something goes wrong.
mike.lo Fri, 07/13/2007 - 03:37
tks for support, the place we deploy is Manila. we try to ask them to change into E1 PRI, but i know that DDI range can't keep. so it is difficult.
besides, is it possible that mgcp can support it in later ccm version, say 6.0?
paolo bevilacqua Fri, 07/13/2007 - 03:44
  • Hall of Fame,
    Founding Member
hi,
CCM 6.0 is out and doesn't support E1 R2. I think the reason is that it is so complicated, that only the router can do it.
