multiple static port nat
Jul 13th, 2007
Hello
It there any feature in IOS to have multiple static port nat on the same port on outside pointing to different ports in the inside like in the following example?
ip nat inside source static tcp 192.168.246.30 2025 172.23.198.30 25 route-map SRC-DST-TEST-25 extendable
ip nat inside source static tcp 192.168.246.30 2026 172.23.198.30 25 route-map SRC-DST-TEST-26 extendable
route-map SRC-DST-TEST-25 permit 10
match ip address SRC-DST-TEST-25
route-map SRC-DST-TEST-26 permit 10
match ip address SRC-DST-TEST-26
ip access-list extended SRC-DST-TEST-25
permit ip host 172.23.198.25 any
ip access-list extended SRC-DST-TEST-26
permit ip host 172.23.198.26 any
I know in ASA OS it is possible to do this together with access-lists in IOS I could not find yet.
Thanks in advance for any answers.
Andre
