I need a Good Start - CCNA
Jul 13th, 2007
Hello World of Geeks! :)
Can any one give me some suggestions for preparing CCNA, i want to take it on Aug 1. Give me some simulators and materials that can be fetched online.
2. I doubt whether cisco study materials online isnt enough for preparation ??
Bye
Take Care
Wilson Samuel Fri, 07/13/2007 - 04:47
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
You can follow the following roadmap (which I have been using since 2001 for all my Cisco Exams)
1. Get the Blue Print
2. First go through the Todd Lammlle Book thoroughly
3. Then and only then, go through the Wendom Odell CCNA book
4. If you are not good at subnetting, make sure you are, otherwise YOU WILL FAIL the exam, and to understand the Subnetting in the most easiest way, please google "Understanding IP Subnetting" and the document from 3Com, would be an excellent source.
5. Meanwhile you can either use any online Rack Rental or you may use the PEC at cisco.com
6. Attempt the exam!!!
HTH,
Please rate if it helps,
Wilson SAmuel
