Where to apply QOS ?
Answered Question
Jul 13th, 2007
  • Bronze, 100 points or more
Hi, After defining the policy maps , how does one decide where and in which direction should the policy be applied ?
Correct Answer by bjornarsb about 9 years 10 months ago
Yes.
Outbound on your CPE router, and make sure that the service provider does the same on their PE router.
Actually you can do classification input on your Eth inteface.
BR,
Bjornarsb
Correct Answer by Jon Marshall about 9 years 10 months ago
Outbound on the Spoke serial interface would guarantee 20kbps of traffic to Hub. To guarantee the return traffic you should apply it outbound at the HUB to each spoke site as well.
Jon
Overall Rating: 5 (2 ratings)
vikram_anumukonda Fri, 07/13/2007 - 06:05
Hi Kerek,
Thanks for the reply, but my question is how to decide whether to apply the policy inbound or outbound on a interface.
If you take a Hub and Spoke environment with each spoke connected to the HUB using a 64 kbps leased line, and i want guarantee an bw of 20kbps for http traffic per branch , where should i applcy the policy ???
class-map match-any HTTP
match protocol http
policy-map HTTP
class HTTP
bandwidth 20
where should i apply this policy ???
HUB Serial inbound or outbound
SPOKE Serial inbound or outbound
I hope you got my question..
Correct Answer
Jon Marshall Fri, 07/13/2007 - 06:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
vikram_anumukonda Fri, 07/13/2007 - 20:00
Hi Jon,
So I need to apply the policy both on Spoke Serial and Hub Serial in Outbound directions, Is that what you meant ?
-vikram
Correct Answer
bjornarsb Fri, 07/13/2007 - 20:50
Yes.
BR,
Bjornarsb
vikram_anumukonda Fri, 07/13/2007 - 21:20
thanks for the reply, It answered my question - vikram
