CSC2611XM
vepachedu
How much bandwidth does this modek cisco 2611xm series router support
1.it has 2 fas eth connections and 1 wic slot with 2 serial ports( which iam not using )
2. planning to take 4E NM card for this router to support my LAN traffic and want to use two existing fas eth's for WAN connectivity from two ISP's.
3.Fas0/0 --6mps and Fas0/1--6mbps
does this router support this much load and can it be used for redundancy .
4.most of our traffic is of graphics ...does this 32/128 flash memory is sufficient or not .
kerek
Level 4
Level 4
You can check the performance of 2611XM on the link:
http://www.cisco.com/warp/public/765/tools/quickreference/index.shtml
Anyway its throughput is 10,24 Mbps as long as you use cef which is strongly recomended.
Anyway it doesen't matter that you wan to transfer graphics as long as you use IP. The memory size mainly affect the image can be loaded to the box and the other things using the dynamic memory (for instance routing table).
If you want to achieve high throughput using Ethernet interfaces the L3 switches the best.
Hope it helps,
Krisztian
