07-13-2007 05:53 AM - edited 03-03-2019 05:51 PM
I am having issue to redistributing 2 vrf-lite routes into my LAN L3 switches.My topology is as below,
PE router having two bgp peering with my CE,
On CE, I having 2 separet routing tables, which I need forwarding to my 2 LAN swiches running EIGRP.
I did try to redistribute BGP into EIGRP but no route is comming into EIGRP, I also configured Static route to forward my one vrf routes to next hop , but still not working. please see my config on CE.
Please note, we need to keep routes sepreate from CE to two lan L3 switches.
CE-3750#
rd 800:1
ip vrf lite3
rd 900:1
interface GigabitEthernet1/0/2
des"connection to-1st-LAN switch"
no switchport
ip vrf forwarding lite2
ip address 11.1.1.1 255.255.255.252
interface Vlan2
ip address 100.1.1.1 255.255.255.252
interface Vlan3
ip vrf forwarding lite3
ip address 200.1.1.1 255.255.255.252
router eigrp 11
redistribute bgp 800
network 11.0.0.0
auto-summary
router bgp 800
network 11.1.1.0
bgp log-neighbor-changes
address-family ipv4 vrf lite3
redistribute connected route-map TEST
neighbor 200.1.1.2 remote-as 100
neighbor 200.1.1.2 activate
neighbor 200.1.1.2 route-map TEST out
no auto-summary
no synchronization
network 20.1.1.1 mask 255.255.255.255
exit-address-family
address-family ipv4 vrf lite2
neighbor 100.1.1.2 remote-as 100
neighbor 100.1.1.2 activate
neighbor 100.1.1.2 route-map TEST out
no auto-summary
no synchronization
network 11.1.1.0 mask 255.255.255.0
exit-address-family
ip route vrf lite2 0.0.0.0 0.0.0.0 11.1.1.2
07-13-2007 06:41 AM
Make sure you either configure a default-metric under the address-family ipv4 vrf xxx or set the metric as part of the route-map as follow:
router eigrp 11
default-metric
default-metric
or
route-map TEST permit
set metric
Redistribution will not take place without this.
Hope this helps,
07-13-2007 07:02 AM
I have changed the config on ce as below, but still unable to recieve Eigrp routes on LAN-SW.
on CE
router eigrp 11
network 11.0.0.0
auto-summary
default-metric 1500 1000 1 255 1500
auto-summary
exit-address-family
on LAN-SW
LAN-SW1#sh ip ro
Gateway of last resort is not set
11.0.0.0/30 is subnetted, 1 subnets
C 11.1.1.0 is directly connected, GigabitEthernet1/0/2
LAN-SW1#sh ip eigrp nei
LAN-SW1#sh ip eigrp neighbors
IP-EIGRP neighbors for process 11
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
0 11.1.1.1 Gi1/0/2 13 00:01:58 8 200 0 3
LAN-SW1#
07-13-2007 07:24 AM
Mohammed,
On the 3750, Can you do a "show ip ro vrf lite2" and "show ip eigrp vrf lite2 topo".
Also if you could try adding the command "autonomous-system 11" under the address-family ipv4 vrf lite2 to see if it solves the issue.
07-16-2007 01:35 AM
Hi, I have added the autonomous-system 11 command, but the routes are not in Topology table, please see the output below,
Routing Table: lite2
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
100.0.0.0/30 is subnetted, 1 subnets
C 100.1.1.0 is directly connected, Vlan2
172.16.0.0/24 is subnetted, 1 subnets
B 172.16.1.0 [20/0] via 100.1.1.2, 2d19h
10.0.0.0/32 is subnetted, 1 subnets
C 10.1.1.1 is directly connected, Loopback1
CE#sh ip eigrp vrf lite2 top
IP-EIGRP Topology Table for AS(11)/ID(10.1.1.1) Routing Table: lite2
CE#
