07-13-2007 06:32 AM - edited 03-14-2019 10:32 PM
I am having the problem in setting up ISDN BRI connection to PSTN. I am runnign Cisco CME 4.1 on Cisco 2801 router platform. I am having simply two Cisco IP phoones. They are registered to CME and I can make the calls between them.
I am trying to make PSTN connection, but without the sucess. I cannot make outside calls and inside calls are not also pssible. In the attachmet there is debug isdn q931 commant.
If some one can help. thanks in advance
Solved! Go to Solution.
07-15-2007 08:19 AM
Understand, TEI is classic case of problems with BRI.
Now, I think that if you get to know username and password that are configured on the Patton, you could eliminate it completely, terminating the SIP trunk directly on the router. An easy way to do that, is to place an ethereral on Patton's ethernet.
To make more ephone ring simultaneously, create an ephone-dn with the called number, then assign this ephone-dn to multiple ephones via button command.
07-14-2007 01:22 AM
It appears that a call got stuck. Please reboot the router. Which IOS are you using ?
07-14-2007 10:19 AM
I am using the following image c2801-spservicesk9-mz.124-11.XJ.bin
I have tried many times but it does not work. I have also to mention that my BRI port is connected to PATTON VoIP router which is terminating NT, and not to clasical NT terminal.
Could it be the problem with the Service Provider or me?
Could it be the problem of IOS, any suggestions:
Waiting for reply,
Thanks in advance!
07-14-2007 10:50 AM
please upgrade to 12.4(11)XJ3 that has many bg fixes.
The send again the q931 traces, for incoming and outgoing once the stuck call has been cleared.
07-15-2007 02:00 AM
I will try to upgrade to 12.4(11)XJ3 IOS version, but it will last for few days.
In mean time I have the IOS version 12.4(3)G 12.4(4)XC4 and 12.4(4)XC6.
Which one would be best to use in order to solve this ISDN BRI connectivity problem?
Thanx in advance,
07-15-2007 02:50 AM
12.4(4)XC6 will work.
In reality any should work, but in the attachment above you had a stuck call. What is your config ?
07-15-2007 04:05 AM
07-15-2007 04:46 AM
I have just solved the problem. I have added the comand
isdn static-tei 0 in ISDN BRI interface and everything is working, outgoing and incoming calls
I was never tolf from Service Provider to asign static tei of 0 !!!!!
I would like to tank you for reply to my messages,
At the end one more question, how do I configure IP phones to ring simultaneously, when the call from outside is received,
Alicic
07-15-2007 08:19 AM
07-17-2007 02:37 AM
hi,
Thanx for the reply. I just made the configuration without the problem,
Thanx once again,
Alicic
07-17-2007 02:38 AM
Thank you for the nice rating and good luck !
