output drops and loss of connection
Hi All,
My core is a cisco 4507R which is connected to my pix for internet. I am experiencing some pretty severe connection loss. The vlan interface on my core directly connected to the pix internet at cannot ping consistently. When I look at the interface on the 4507R I see a LOT of output dropped packets. At the time of writing this it looks like this:
GigabitEthernet3/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 000f.2473.07a2 (bia 000f.2473.07a2)
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 42/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 13985536
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 325000 bits/sec, 70 packets/sec
5 minute output rate 16695000 bits/sec, 1466 packets/sec
26433 packets input, 16958019 bytes, 0 no buffer
Received 2 broadcasts (0 multicast)
1541681 packets output, 2205973562 bytes, 0 underruns
0 lost carrier, 0 no carrier
I can only think that the "total output drops" being so high has somethign to do with my connection loss. can someone provide some info?
Prashanth Krishnappa Sun, 07/15/2007 - 15:56
What kind of line card do you have in slot 3 of this 4507R. If its a 48 port gigabit line card, keep in mind that its oversubscribed 8 times.
Also, issue a sh int gig 3/3 counters detail and see if the drops are due to RX-Flowcontrol.
