dot1x configuration on 6509
Jul 13th, 2007
I'm running IOS v12.2(18)
When I'm trying to configure the interface, i'm expecting to see the commands "dot1x guest-vlan" and i don't see it. Everything is set up globally and i have the port-control auto set. There is also no auth-fail vlan to set for the port either. Thanks for any help.
Overall Rating: 3 (1 ratings)
Amit Singh Fri, 07/13/2007 - 09:36
  • Cisco Employee,
These features are currently not supported on Cat6500 with 802.1x authentication. These features will be available in the next IOS release for Cat6500.
HTH,Please rate if it does.
-amit singh
Sean Graham Fri, 07/13/2007 - 10:45
Any idea of when this version of IOS will be coming out? Thanks again.
