VPN Client and Apple iMac Problem
Jul 13th, 2007
I have installed successfully the CISCO VPN client 4.9.01 0080 on my Apple iMac OS X 10.4.10.
I launch the client without problems, i connect to my CISCO VPN 3000 concentrator, but when i'm connected to VPN i cannot access my remote network nor internet, seems that i loss all routes.
When i close the connection to VPN i can't access internet as usual.
Any idea?
Thanks for your help
sadbulali Thu, 07/19/2007 - 09:51
When you launch the SGM client, the GTT Configurator, or the Event Configurator, or when you connect to a new server (whether manually or automatically as the result of a server failure), you might receive the following message:
This client is not allowed to connect to the server or the server is listening on a port the client does not know about or cannot reach. Click the help button for a more detailed explanation
1. An SGM administrator has prevented your SGM client from connecting to the SGM server, using the sgm ipaccess command.
http://www.cisco.com/en/US/docs/net_mgmt/signaling_gateway_manager/3.2/user/guide/sgmufaq.html#wp1080821
