Warning message
How to change hardware without CM upgrade
Jul 13th, 2007
I found plenty of doc on changing hardware while doing a hardware upgrade. Is there a doc on changing hardware without upgrading CM? Is it possible to change the CM's IP address during the hardware change? Thanks for any advice.
Overall Rating: 5 (2 ratings)
mchandak Fri, 07/13/2007 - 11:15
  • Gold, 750 points or more
If you intend to move your CM from one machine to another you need to do the following:
1. Take a Backup of the system using BARS.
2. Install the new machine with the same Hostname and IP Address.
3. Once install, use the same version of BARS to do a restore it on the new server.
Also, since you would be used the same HostName and IP Address, you need to ensure both the servers are either not powered on at the same time or you install the new box within an isolated Lab and when the server is good to be connected to the Production setup, you should either disconnect or Power down the old server
Rob Huffman Thu, 09/27/2007 - 04:50
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Ben,
Thanks for sharing your experiences with us :) We all have those "magical moments" don't we. 5 points for your good natured approach here!
Take care,
Rob
