3750 (secondary) lost PoE
Jul 13th, 2007
Have you ever seen such a thing?
(2) 3750 switches, stackwise configuration.
After a power outage, the second switch is no longer providing PoE on its ports.
royalblues Sat, 07/14/2007 - 07:39
  • Green, 3000 points or more
The only POE problem i have experienced is due to the bug CSCsc10999 wherein the Switch does not power PD when non-PD device previously plugged into port rectified in 12.2.25SED and higher versions
Narayan
Edison Ortiz Sat, 07/14/2007 - 07:59
  • Hall of Fame,
    Founding Member
Can we see the output from typing
show power inline
Consuelo Annon Tue, 08/03/2010 - 13:41
Yes We have had several of these. inline power says off
phone works on port in slave switch
set to static plugged in phone power flicked to off
rebooted switch all is fine
could this be related to length of power outage and size and capacity of UPS?
