lfulgenzi Fri, 07/13/2007 - 13:06
If you are downloading a devpack, I believe this should update the device defaults page for you. If you are using the zip file, then you have to do that yourself.
Either way, if you read the release notes, you will see the file names present in the upload. Follow the format that was there before and simply replace with the new version.
By format, I mean, sometimes they want a .BIN/SBIN at the end, sometimes they don't.
Lelio
