Warning message
Problems with a NM-HDV2-2T1/E1
Jul 13th, 2007
I have a 2821 with an NM-HDV3-2T1/E1 network module installed. I have an VWIC2-2MFT-T1/E1 installed in the open slot. The VWIC is connected to 2 data T1s and they are working fine(t1 1/0/0 and 1/0/1). The problem I am having is defining the onboard T1s as data T1s. When I define the controller and the channel group on t1 1/0 ( channel-group 0 timeslots 1-24 speed 64) I get and error message:
%Insufficient resources to create channel group
Here is the controller configs:
controller T1 1/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/0/0
framing esf
linecode b8zs
detect v54 channel-group 0
controller T1 1/0/1
framing esf
linecode b8zs
Is there something special I need to do to get the onboard T1s defined for data?
Thanks, Steve
vinay_verma80 Sun, 07/15/2007 - 12:43
hi
i suppose u need dsp in ur router. check how many dsp u have , add more dsp
( u can be sure of this by reducing time stols try "channel-group 0 timeslots 1 speed 64" command , if router take the command u can increase the time slots untill it give u the same error )
regards
paolo bevilacqua Sun, 07/15/2007 - 17:11
  • Hall of Fame,
    Founding Member
The thing is that "channel-group" does not uses DSP and it is a data configuration, not voice.
This case should be given to the TAC in my opinion.
ssjoberg Mon, 07/16/2007 - 15:29
Thanks for the input. I have opened a TAC case.
vinay_verma80 Thu, 07/19/2007 - 09:52
hi
I still think this is because of dsp
u can try the method it will hardly matter of 10-15 min after that if does not solve u can go a open a tac case
regards
paolo bevilacqua Thu, 07/19/2007 - 14:32
  • Hall of Fame,
    Founding Member
Let's wait for the answer from TAC to ssjoberg.
Perhaps it will come out that VWIC in the slot on NM-HDV cannot be used for data, although this is not evident from any document.
It should work in an HWIC slot on the 2821, if available.
jerry.mcrae Fri, 07/20/2007 - 08:44
it will come down to router resources. i have a 3745 with an nm-hdv2 and a 2 port t-1 trunk controller installed and i couldn't turn up the new t-1 on the 2nd port. i maxed out the dsp on the module and even decreased the size of the trans coding and conference config with no luck. i think i need to add memory to the router and not the module. just my $.02.
paolo bevilacqua Fri, 07/20/2007 - 09:15
  • Hall of Fame,
    Founding Member
Hi Jerry,
No it shouldn't be the memory. To create serial interfaces (channel-group), the router needs something called "HDLC framer". It is the device than handles serial communication and it can be located in different places depending the router architecture.
