CCIE Lab practice at CCIE4U
Jul 13th, 2007
I would just like to know if ccie4u.com will give you scenarios in where you can practice CCIE routing and switching. Are they going to give you exam objectives? Or you are just going to rent the rack and do whatever you want without any objectives?
John
Overall Rating: 4 (1 ratings)
eriknixon Fri, 07/13/2007 - 21:20
They give u the rack. Its up to you to either purchase some labs. CCIE 4u has their racks physically connected for the internetworkexpert.com CCIE labs. I belive u have to purchase the scenarios from internetwork expert.
John Patrick Lopez Sat, 07/14/2007 - 16:17
Now it is getting and getting unfair. Why is that you should have the "means" in order to get what you want? You cannot just practice what you have learned. =( Thanks for the reply Erik.
