Jon Marshall Sat, 07/14/2007 - 00:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You don't say which IOS version you are using but yes it is perfectly possible to configure vlans on the 7613.
Attached is a link to configuration guide for 12.2sx on the 7600. You need to look at the following chapters
Configuring vlans
Configuring layer 3 interfaces
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_book09186a00801d4269.html
Jon
vinay_verma80 Sat, 07/14/2007 - 05:10
hi
in any switch u should be able to create vlan
if it is ios version then u can use the command
if the interface is ip interface use command
#switchport( interface config mode)
after that is normal config
ie go to config mode
vlan 100- to create vlan
regards
