Jul 13th, 2007
I am trying to find an OID that keeps track of SIP calls in a voice gateway. Does anyone know of one?
Any suggestions on how to track active calls besides snmp?
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Sat, 07/14/2007 - 10:48
There is specific MIB for SP, the general voip MIBs apply.
Beside SNMP, you can track calls using radius accounting to a server.
There also off-the shelf billing solution that will od everything for you, example stonevoice.
sergio.danelli Sat, 07/14/2007 - 11:12
thanks for your reply. Do you know the exact OID for this?
I am using Solarwinds Orion and building a custom MIB poller for this. I just can't find the exact OID.
Paolo Bevilacqua Sun, 07/15/2007 - 17:21
There is more than one MIB that you can use. Search CCO for "voice call mib".
