HSRP not working
Answered Question
Jul 14th, 2007
i configured HSRP on my both 6500 switches, but its still not working, i need help here please here is the output
Router#show standby
FastEthernet4/48 - Group 1
Local state is Active, priority 51, may preempt
Hellotime 3 holdtime 10
Next hello sent in 00:00:02.758
Virtual IP address is 1.1.1.1 configured
Active router is local
Standby router is 1.1.1.2 expires in 00:00:07
Standby virtual mac address is 0000.0c07.ac01
1 state changes, last state change 00:18:54
Tracking interface states for 1 interface, 1 up:
Up FastEthernet4/13
interface FastEthernet4/48
ip address 1.1.1.3 255.255.255.0
no ip redirects
standby 1 priority 51 preempt
standby 1 ip 1.1.1.1
standby 1 track Fa4/13
Correct Answer by royalblues about 9 years 11 months ago
Friend,
You are missing the preempt command on the second router. The preempt command will make sure the standby takes over the control when the primary is active but the priority is reduced.
If the preempt is not configured, then eventhough the priority becomes low, the standby will not take the active role as long as it is receiving hellos from the active one.
configure "standby preempt" in the second router and let us know how it goes
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
tariqsako Sat, 07/14/2007 - 00:40
when i turn off the active router.. the second doesnt go ACTIVE.. or when i remove one of the tracked interfaces.. please help me.. 2 days i'm working on this and its not working
bjornarsb Sat, 07/14/2007 - 03:04
  • Bronze, 100 points or more
To help you we need the output of you second router.
Have you tries to configure standby 1 mac ?
BR,
Bjornarsb
glen.grant Sat, 07/14/2007 - 03:07
  • Purple, 4500 points or more
You will have to post the configs of both routers and indicate which interfaces they are connected together with . All this really tells us is you have configured hsrp on one side , need more information .
tariqsako Sat, 07/14/2007 - 23:23
Dear Sir, sorry for being late on you, i attached to you the configuration from the 2 switches, you can see on the second switch, thats it having higher priority but its not becoming active. if i pulled the 4/48 cable physically out and then in to the port immediately, it becomes the active one !! i really appreciate your help.
Correct Answer
royalblues Sat, 07/14/2007 - 23:48
  • Green, 3000 points or more
Friend,
Narayan
