Trunking
Answered Question
glen.grant Sat, 07/14/2007 - 12:01
Because that switch is so old it does not use the same commands as newer ios switches.
glen.grant Sat, 07/14/2007 - 14:54
Understood I am just telling you the reason , there are differences between that old 2924 and say a 2950 as far as commands go and you should keep that in mind if are studying for certs because I believe they base the tests on a 2950 or higher.
