I can't send image to my ASA with tftp
Jul 14th, 2007
I have erased the startup config and reloaded ASA 5510. Now its not able to boot preoperly.
I used rommon mode to transferth image file to my ASA, the transfer is made succefully, but when i attempt to use copy tftp flash, i receive this error message :
ciscoasa# copy tftp flash
Address or name of remote host [10.10.10.3]?
Source filename [asa802-k8.bin]?
Destination filename [asa802-k8.bin]?
Accessing tftp://10.10.10.3/asa802-k8.bin...!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
%Error copying tftp://10.10.10.3/asa802-k8.bin (Not enough space on device)
when I execute dir and show flash command:
ciscoasa# dir
Directory of disk0:/
432 drw- 0 08:57:09 Jul 14 2007 crypto_archive
426 drwx 0 08:56:56 Jul 14 2007 log
0 bytes total (0 bytes free)
ciscoasa# sh flash:
--#-- --length-- -----date/time------ path
432 0 Jul 14 2007 08:57:09 crypto_archive
426 0 Jul 14 2007 08:56:56 log
I though that there is no flash memory in my appliance then I use show version that display:
ciscoasa# show version
Cisco Adaptive Security Appliance Software Version 8.0(2)
Compiled on Fri 15-Jun-07 19:29 by builders
System image file is "tftp://10.10.10.3/asa802-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 36 mins 35 secs
Hardware: ASA5510-K8, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
Slot 1: ATA Compact Flash, 32MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.01
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 0019.e8d9.4854, irq 9
1: Ext: Ethernet0/1 : address is 0019.e8d9.4855, irq 9
2: Ext: Ethernet0/2 : address is 0019.e8d9.4856, irq 9
3: Ext: Ethernet0/3 : address is 0019.e8d9.4857, irq 9
4: Ext: Management0/0 : address is 0019.e8d9.4858, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
<--- More --->
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 50
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
Advanced Endpoint Assessment : Disabled
This platform has a Base license.
Serial Number: JMX1106K0XM
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Configuration register is 0x1
Configuration last modified by enable_15 at 09:01:10.061 UTC S
I used another externat flash as you can see in the output of sh version but I have alwase the same problem.
Can anyone help me Please.
Overall Rating: 3 (2 ratings)
pcomeaux Tue, 07/17/2007 - 20:28
  • Cisco Employee,
Hi -
Based on what I see searching all open/closed TAC cases, it appears your ASA may have a corrupt flash, as is the case with a few other cases that I found.
I would suggest opening a TAC case under initial warranty to see if you can get a replacement.
thxs
peter
peter
a-akarmou Wed, 07/18/2007 - 01:14
thanks for your help; but I think I found the solution.
What I did is I simply format the memory flash of ASA and after reboot, all things are good.
