default route and default gateway
Answered Question
Jul 14th, 2007
Is there anybody out there knowing wath is the difference between default route and default gateway in router ?
Thanks in advanced
Correct Answer by Jon Marshall about 10 years 1 week ago
Yes to all intents and purposes. If the router had ip routing turned off and you wanted the router to talk to other machines on different vlans/subnets it would need to have a default gateway.
Jon
Overall Rating: 5 (2 ratings)
glen.grant Sat, 07/14/2007 - 11:58
  • Purple, 4500 points or more
default gateway is used if ip routing is turned off on the router to get off the router. A defualt route is used when ip routing is turned on but their is no route in the table for the destination, that traffic gets sent to the default route.
amanolahi Sat, 07/14/2007 - 12:04
does that means that the default gateway is used, if the route acts as a end system? Like a l2 switch?
Correct Answer
Jon Marshall Sat, 07/14/2007 - 14:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
