RADIUS load balancing
Jul 14th, 2007
Our users authenticate via IAS Radius (active directory). I have one IAS Radius server configured on our concentrator, how would I load balnce Radius adn also create redundancy?
I was thinking if I add a 2nd Radius to the concentrator for authentication for it automatically load balance? And if one IAS server was down would it use the other one?
johnd2310 Sat, 07/14/2007 - 20:38
  • Silver, 250 points or more
That should work for redundancy. Concentrator will use 2nd radius if the first does not answer. Load balancing will need other method.
John
johnd2310 Mon, 07/16/2007 - 01:44
Depends on he version of Windows you are running. If you have Enterprise edition you can look at Windows Clustering. If you are running the standard edition then you can have a look at network load balancing. In your case i think you want to look at Network load balancing.
http://support.microsoft.com/kb/323437/
regards
John
whiteford Mon, 07/16/2007 - 02:29
Could I just add a 2nd Radius server to the concentrator then? and if it can't contact one IAS Radius server then it will try the other one in the list?
johnd2310 Mon, 07/16/2007 - 11:37
Yes, that should be fine. Most people use that config. You would only look at clustering and load balancing if you have heaps of athentication connections.
regards
John
