Not Able to Launch PDM on PIX 501
Jul 14th, 2007
When I try to lauch PDM on my PIX 501 by typing the ip address of the PIX in IE, I receive the following error:
The startup wizard is not supported on the FWSM.
These are the versions:
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
When I click OK on the message, the PDM web page does not get loaded and it's stuck at "loading startup wizard, please wait..."
Any one with any idea why this is happening?
Thanks in advance.
Sam
hburgos Mon, 07/16/2007 - 08:43
Sam
Sounds like your using the wrong Java version.
Hank
spahlavan Tue, 07/17/2007 - 17:53
Hi Hank:
Thanks for your response.
I upgraded from Java 2 Runtime Environment 1.4.2_03 to Java SE Runtime Environment version 6 Update 1. I will let you know if I still get the error message after the upgrade or not.
