ISDN DDR Troubleshooting
Jul 14th, 2007
I have a point to point link with ISDN DDR on both sides. DDR seems to be working, at least it attempts the call. The remote site is able to connect just fine. But the H.O. side can not connect.
debug isdn events gives the following:
ISDN BR1/6: received HOST_DISCONNECT call_id 0xB56A
3w2d: ISDN BR1/6: Event: Call to 065323276 was hung up.
3w2d: ISDN BR1/6: process_disc_ack(): call id 0xB56A, ces 1, call type DATA
3w2d: ISDN BR1/6: Outgoing call id = 0xB56B, dsl 14
3w2d: ISDN BR1/6: Event: Call to 065323276 at 64 Kb/s
3w2d: ISDN BR1/6: process_bri_call(): call id 0xB56B, called_number 065323276, speed 64, call type DATA
3w2d: ISDN BR1/6: received HOST_PROCEEDING call_id 0xB56B....
3w2d: ISDN BR1/6: received HOST_DISCONNECT_ACK call_id 0x80D6A71C
3w2d: ISDN BR1/6: HOST_DISCONNECT_ACK: call type is DATA.
Success rate is 0 percent (0/5)
bhemain#
3w2d: ISDN BR1/6: received HOST_DISCONNECT call_id 0xB56B
3w2d: ISDN BR1/6: process_disc_ack(): call id 0xB56B, ces 1, call type DATA
3w2d: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/5, TEI 105 changed to down
3w2d: L3: L3_GetUser_NLCB failed, message ignored cid 0x0 cr 0x27 ev 0x4D ces 1 dsl 14
3w2d: L3: L3_GetUser_NLCB failed, message ignored cid 0x0 cr 0x28 ev 0x4D ces
I also sometimes get a 'no user responding' error. Line noise? Thanks for the help in advance.
Prasenjit
spremkumar Sun, 07/15/2007 - 20:13
  • Red, 2250 points or more
Can you post the configurations here ?
regds
prasenjitmedhi Sun, 07/15/2007 - 21:45
H.O.:
hostname
ip subnet zero
isdn switch-type basic-net3
username password 0
interface bri 1/6
ip address 191.x.x.30 255.255.255.0
no ip directed-broadcast
encapsulation ppp
dialer idle-timeout 300
dialer map ip 191.10.30.29 name broadcast
dialer map ip 191.10.30.60 name broadcast
dialer-group 1
ppp authentication chap
hold-queue 75 in
ip route 200.x.x.0 255.255.255.0 191.10.30.29
Remote Site
hostname
username password 0
ip subnet zero
interface BRI0
ip address 191.x.x.29 255.255.255.0
encapsulation ppp
dialer map ip 191.10.30.30 name broadcast
dialer hold-queue 30
dialer-group 1
no fair-queue
ip route 200.1.x.x.255.255.0 191.10.30.30
Thanks for your suggestions in advance,
Prasenjit
spremkumar Sun, 07/15/2007 - 21:57
hi
can you revert on the reason behind addressing the bri interface with a whole /24 mask ?
Are you using this link as a primary link or using this as backup for redundancy ?
regds
prasenjitmedhi Sun, 07/15/2007 - 22:08
I just joined this company about 2 months ago. The last network admin used a network addressing scheme where he used Public IP's, behind a NAT with great liberty. _Terrible!!!!_networking practice, I know, but, I have not gotten approval yet to overhaul addressing in the system in entirety, yet. I'll change over to a private addressing scheme as quickly as I can. Its a bit like a SOHO network grown overly large .. But its a family owned SME .. and things move slowly .. Its not Wipro :)
This is the primary link, sir.
Thanks and regards,
Prasenjit
spremkumar Sun, 07/15/2007 - 22:41
Can you post the output of debug isdn q931 ?
regds
prasenjitmedhi Sun, 07/15/2007 - 22:53
When H.O. dials remote:
3w3d: ISDN BR1/6: Outgoing call id = 0xB615, dsl 14
3w3d: ISDN BR1/6: Event: Call to 065323276 at 64 Kb/s
3w3d: ISDN BR1/6: process_bri_call(): call id 0xB615, called_number 065323276, s
3w3d: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/6, TEI 91 changed to up
3w3d: ISDN BR1/6: TX -> SETUP pd = 8 callref = 0x53
3w3d: Bearer Capability i = 0x8890
3w3d: Channel ID i = 0x83
3w3d: Called Party Number i = 0x80, '065323276'
3w3d: ISDN BR1/6: RX <- CALL_PROC pd = 8 callref = 0xD3
3w3d: Channel ID i = 0x89
3w3d: ISDN BR1/6: received HOST_PROCEEDING call_id 0xB615.....
3w3d: ISDN BR1/6: RX <- DISCONNECT pd = 8 callref = 0xD3
3w3d: Cause i = 0x8292 - No user responding
3w3d: ISDN BR1/6: received HOST_DISCONNECT call_id 0xB615
3w3d: ISDN BR1/6: Event: Call to 065323276 was hung up.
3w3d: ISDN BR1/6: process_disc_ack(): call id 0xB615, ces 1, call type DATA
3w3d: ISDN BR1/6: TX -> RELEASE pd = 8 callref = 0x53
3w3d: Cause i = 0x60 -
3w3d: Cause i = Decode Error: len -1 overflows frame -
Decode Error: IE Length Error (0xC8)
3w3d: Cause i = Decode Error: len -1 overflows frame - Service/option no
t available, unspecified
Decode Error: IE Length Error (0xF1)
3w3d: ISDN BR1/6: received HOST_DISCONNECT_ACK call_id 0x80D7B410
3w3d: ISDN BR1/6: HOST_DISCONNECT_ACK: call type is DATA
3w3d: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/5, TEI 105 changed to down
3w3d: ISDN BR1/6: RX <- RELEASE pd = 8 callref = 0xD3
3w3d: L3: L3_GetUser_NLCB failed, message ignored cid 0x0 cr 0x53 ev 0x4D ces 1
dsl 14
3w3d: ISDN BR1/6: TX -> RELEASE_COMP pd = 8 callref = 0x53
3w3d: Cause i = 0x80D1 - Invalid call reference value
Remote is able to dial into H.O. just fine.
spremkumar Mon, 07/16/2007 - 00:05
Based on the disconnection code 0X8292 following are the possible reasons for the connectivity issue..
82?the public network near the local user (local telco switch)
92 - No user response
The connection fails because the destination does not respond to the call.
This cause indicates that a user does not respond to a call establishment message within the prescribed period.
The user must respond with either an alert or connect indication according to ITU-T Q.931, when either timer T303 or T310 expires.
regds
prasenjitmedhi Mon, 07/16/2007 - 00:41
Thanks for all the assistance Prem Kumar sir!
Could line noise be a factor? Would it hurt to ask the Telco to take a look at the remote line?
Or is it more likely some kind of funky memory/ modem chipset problem with the BRI port on the remote site or at the H.O. side, that only crops up on LCP/NCP negotiation?
The two solutions that occur to me are:
1. Try using a different router at the remote site.
2. Get the remote line checked.
Thank you for all the help and suggestions. Look forward to further feedback.
