HWIC-2811 router
Jul 14th, 2007
hi,
i am using 4 ports HWIC in 2811 router for LAN interface. All ports are layer 2 ports unable to assign ip address. I am using advance security IOS 12.4(5)trying to create vlan. but unable to enter vlan in data base, when trying to map one of port of HWIC to that port its giving error vlan not in database...i am unable to find any command for this supported in this IOS.
i want to use thses ports as layer-III ports. Any idea? I'll appriciate your response.
Overall Rating: 5 (1 ratings)
royalblues Sat, 07/14/2007 - 23:26
  • Green, 3000 points or more
Aziz,
If you are talking of the HWIC-4ESW module, then as per the data sheet, these ports cannot be used as a routed port. However you can definitely go to the VLAN database mode and configure VLANS and SVIS
Have a look at this link
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804554c7.html#wp1043332
Narayan
glen.grant Sun, 07/15/2007 - 06:46
  • Purple, 4500 points or more
They cannot be used as a routed port per se but the port should still be routable, just create a layer 3 SVI for the vlan and then put the interface into that vlan .
router#vlan database -->hit enter
vlan 10
exit
interface vlan 10
ip address 192.168.10.1 255.255.255.0
interface f4/0
switchport access vlan 10
