HWIC in 2811
Jul 14th, 2007
HWIC is layer-II device i am using in 2811 i want to convert this to layer-III so i can assign ip address on ports. no Switchport cmd is also not working. i am trying to creat vlan but could not enter in vlan database. using 12.4 advance security IOS.
I want layer-III interafce for LAN?? please advice what 2811 supports in this module?? i tried using NM2FE2W but to no avail....its not compatible i think...yellow link blinks and then goes off......
please advise...
royalblues Sat, 07/14/2007 - 23:11
  • Green, 3000 points or more
Friend,
If you want an additional ethernet module, you can use the HWIC-1FE (the min IOS required though is 12.4(11) XJ)
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd80581fe6.html
HWIC-16ESW is also supported on the 2811 which gives you 16 ports and can be configured for VLAN interfaces
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html
The 2811 also supports the NM-16ESW module
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aca3e.html
Have a look at the 2800 data sheet for the supported modules for your needs
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
HTH, rate if it does
Narayan
paolo bevilacqua Sun, 07/15/2007 - 03:05
  • Hall of Fame,
    Founding Member
beside Narayn's good advice, there is no need to create use vlan database commands, just configure interface vlan X and assign the needed ports to it.
What does it mean the switchport command doesn't work? Please be more specific.
aziz.imran Sun, 07/15/2007 - 16:10
I created VLAN but interface status showing down. secondly i want to use that interface for GRE/IPSEC.
paolo bevilacqua Sun, 07/15/2007 - 17:08
  • Hall of Fame,
    Founding Member
Config and show interface please ?
jay77jay77 Sun, 07/15/2007 - 20:17
hi aziz,
Advanced security IOS i belive shudn't hinder you from entering VLAN Database.
Nevertheless, you can:
1. create a vlan using " int vlan x"
2. Assing the FE switch port using "switch port access vlan X"
3. Connect that switch port to a router
4. sh ip int brief, you can see the port is up as well the VLAN X.
Cheers!
jay77jay77 Sun, 07/15/2007 - 20:27
IPSEC/GRE may have issue on HWIC port, as it have limited functionality.You may test it out.
