without installing Cisco VPN client (clientless vpn )on PCs.
Jul 14th, 2007
We need to setup the VPN connection through the 515 firewall directly so it will be transparent to the end user without installing Cisco VPN client(clientless vpn) on PCs.
JORGE RODRIGUEZ Sun, 07/15/2007 - 08:23
hi, I have not heard of clientless vpn on PCs and be able to statblish a vpn connection, what I think you are refering to is site-to-site IPSec VPN Connectivity where you stablish a fixed vpn tunnel through two sites using pix to pix or pix to router, or vpn concentrators .. if this is what I think you're refering to go to this link.. if not could you clarify.
VPN site-to-site with PIX
check site-to-site IOS section
